H
honda-ryder
·Guest
[B]Engine:[/B] Four-stroke, liquid-cooled, DOHC, parallel twi
Engine: Four-stroke, liquid-cooled, DOHC, parallel twin
Displacement: 296cc
Bore x stroke: 62.0 x 49.0mm
Compression ratio: 10.6:1
Cooling: Liquid
Fuel Injection: DFI® with dual 32mm throttle bodies
Ignition: TCBI with digital advance
Transmission: Six-speed
Final drive: Chain
Frame: Semi-double cradle, high-tensile steel
Wheelbase: 55.3 in.
Rake / trail: 27 degrees / 3.7 in.
Front suspension / wheel travel: 37mm hydraulic telescopic fork / 4.7 in.
Rear suspension / wheel travel: Uni-Trak® with 5-way adjustable preload / 5.2 in.
Front tire: 110/70-17
Rear tire: 140/70-17
Front brake: Single 290mm petal-type disc with two-piston hydraulic caliper
Rear brake: Single 220mm petal-type disc with two-piston hydraulic caliper
Overall length: 79.3 in.
Overall width: 28.1 in.
Overall height: 43.7 in.
Seat height: 30.9 in.
Curb weight: 379.3 lbs.
Fuel capacity: 4.5 gal.
Color choices / special edition: Pearl Stardust White, Lime Green / Ebony, Ebony
Warranty: 12 months
Optional Good Times™ Protection Plan 12, 24, 36 or 48 months
Source: Honda USA
Displacement: 296cc
Cooling: Liquid
Final drive: Chain
Wheelbase: 55.3 in.
Warranty: 12 months
Source: Honda USA
