Ordered a rear rack from Bikerz Bits on the 14 June. Delivered to the UK today (25th). Package had been opened by Customs, not a surprise considering the senders address! Here are the photos and comments on the fitting.
The Instructions - Just like Ikea, thankfully the pictures make it easy, as I dont read Thai!
What you get for your money
Remove seat, identify the bolts that hold the tail on
Only one bolt is a bit awkward, I had to unclip some wires to get to it. WARNING, the bolt can fall into the frame tube, be careful!
Tail Falls Off - for those of you who not like Tail, this is how you remove it to fit a different rear end!
Rack simply fits between the top of the Tail and the Seat Pan using the new bolts supplied with the rack - longer. You will need 12mm socket / spanner for this job.
Top View, with wires reclipped
Now the bit some people may HATE
I need a Top Box for when I park at the Station (keep Helmet and Waterproof one-piece in). I use a removable Top Box so I can take it off when just out for a ride, rather than commuting to the Rail Station.
Top Box mounting plate fitted to the rack
Top Box mounted (removable)
Drivers View
Rear View (before Rack fitted)
That's All Folks!
Drivers View
That's All Folks!
