Trying to balance my new Gold Grom rims and my Michelin rear tire 140/70-12 and the amount of stick on wt I had to use was 4x 1/4 oz, I think that is too much wt. Are other Grom riders that do their own tire balance using the same stock rim and tire like my setup what wt you put on the rim?
at that much weight on such a small wheel, i'd try to break the bead, and rotate the tire 180*. probably you matched up the heavy spot in the rim and the heavy spot in the tire.
