Where did you get it and how much? I changed out my front flashers last night and mine don't blink either.You want an electronic flasher not a mechanical one. I put one on my grom. The stock flasher is only 2 post. The flasher I got is 3 post. The third is ground so I just hooked it to ground and LEDs flash like they should. I still have stock fronts. You can run all led or all regular bulbs or a combo of the 2 with an electronic flasher
Flasher is behind the headlight. Pretty easy to get to. Once you remove the light and unplug the bulb the flasher has easy access. The stock flasher has a piece of rubber that mounts around a metal tab (like most flashers Honda uses). The new flasher did not, but I simply zip-tied it to the bracket and haven't had a problem.Wheres the flasher on the Grom? I havent looked yet. .
Is their more of a study way to mount it rather than using zip ties?Flasher is behind the headlight. Pretty easy to get to. Once you remove the light and unplug the bulb the flasher has easy access. The stock flasher has a piece of rubber that mounts around a metal tab (like most flashers Honda uses). The new flasher did not, but I simply zip-tied it to the bracket and haven't had a problem.
