As we have discussed before.
Some guys want a gear indicator, some don't.
Some guys want a shift light, some don't
We like to have both, so we installed the Starlane Digital Gear indicator w/ LED Shift light on our Project Grom this weekend.
This device will work on anything with a motor and gears. Up to 9 gears.
And it has a programmable LED Shift light that you can set for any RPM you want, and it will fire off telling you, it's time to shift.
The Gear indicator is sold by itself... as a universal fit.
So if you know your wiring, and like to splice...... you don't need anything else.
BUT...... they also offer a "optional" Plug-n-Play wire harness.
We just wanted a quick and simple install... so the optional harness was a no brainer for us.
Install was very quick, only needing to access the back of the dash panel you just remove the headlight, and the rubber boot and plug are right there.
Simply plug in the OEM connector into the dash, and the other end goes into the Stock Wire Harness. The 3'rd plug goes into the Gear indicator.
You can mount it pretty much anywhere you like.
After a few minutes of programming it, the unit worked as advertised.
It's constantly "Learning" your bike even after programming, so we did notice the more we rode the faster the response time for the gear changes were on the dash.
The Super Bright LED Shift light was a nice addition as well.... since the Grom gets to 8500rpm very quickly.
Most guys who have never had a gear indicator or a Shift Light, don't think they need one.
But, once you have had one on your bike..... it's a really nice feature to have.
Click here to see complete Video of Installation and review.
[ame="http://www.youtube.com/watch?v=3WyPM0-X4sQ&feature"]www.youtube.com/watch?v=3WyPM0-X4sQ&feature[/ame]
Great News........... The plug-n-play wire harness have arrived in the U.S.
Should clear customs and be in our store in 24 hrs.
All back orders will be filled as soon as we get them.
