1 - 3 of 3 Posts
does the crack distort the fibre? If is only surface then get a good quality clear froma hobby shop and dab some into the crack with a brush, let it cure and sand flush with 380 grit wet and dry then polish out.
If it distorts/penetrates the fibre then contact them to see what resin they used, get a small sample of the same from someone near you and use a syringe and needle to inject it into the crack, when cured sand and polish with wet and dry... should be invisible when finished. If you inject the resin carefully enough you can avoid having to sand and polish... do it slowly because it will only need a very small amount to fill the crack.
1 - 3 of 3 Posts
