I
ionized
·Guest
I emailed Racetech about the availability of GVE for the Ninja 125 and received this response:
[QUOTE]Yes we will be offering a GVE for that bike, The forks are the same diameter as the 250 so it may even be possible that the 125 will use the same
I emailed Racetech about the availability of GVE for the Grom 125 and received this response:
What is a Gold Valve Emulator you may ask?
So we can expect that they will either offer a new version of the GVE for the 125, or perhaps we can use the existing model meant for the 250. We should know more over the coming months of course.Yes we will be offering a GVE for that bike, The forks are the same diameter as the 250 so it may even be possible that the 125 will use the same GVE, We will need to confirm that first though.
I installed a pair in my 04' 250 along with higher rate springs and good oil, and noticed a significant improvement in handling and general ride quality on that bike. I expect that similar results will be had on the 125 so it is definitely on my list of upgrades.Simply put; Emulators make damping rod forks perform like well-tuned cartridge forks.
