Engine Upgrade
great, looks like july will be a good month since we'll see your grom build plus many others that get the bore kit.
have you started looking into your exhaust options?
I already have a stainless steel down pipe, once i find a single exhaust i like ill get it.
As far as efi controllers, ill be writing to a few manufacturers to see if any of them are interested in developing one for the msx. The Efi system should, to some extent, automatically adjust itself to maintain the stoichiometric mixture. The problem is, at what point will the injector reach full duty cycle? I think with a mild bore kit it should be fine, but to tune it for maximum hp and torque a controller will be needed with a wide band o2 sensor. I like the idea of the EJK, controller and im sure its possible.
With the engine being so new it seems not many companies have been able to develop maps yet for them, second there is probably little demand now. I believe once peoples warrarties expire is when the demand for the engine mods will really take off. For me i don't care. I bought this think to experiment and play around with.
There is always the option of using a micro-squirt controller and i might use that if nothing else is available. That option would give me max control, but would be a bit overkill for a single cylinder engine.
