Help! I recently installed a integrated tail light, HD relay, and flush mount (two wire) front signals. The signals flash and brake light works, but for some reason now, the headlight doesn't. I've changed the bulb with another OEM, and I've also confirmed that the fuse was good. What else should I check?
If it helps I've attached the wiring setup (borrowed from this site) I used to get the signals to work.
thanks in advance for any help with this
