1 - 5 of 5 Posts
Hi I’m new here and just wanted to know if anyone had any idea on how to test the stator on my 17 grom
I got into an accident about a year ago and just finished putting the bike together I have no parasitic draw just the bike doesn’t charge while riding
The colors on the connector are
White
Green
White yellow
Blue yellow
I also provided pics thanks for the help in advanced
Oh I already replaced the rectifier (silver box), rectifier assy. (Little relay looking thing), and the battery
Measure resistance between the White and the Green wires in the connector , should read between 0.2 and 1 ohm
Just the White and Green , the White/Yellow and Blue/Yellow striped wires are the crankshaft position sensor .
[MENTION=44882]hondarider[/MENTION] I got around to testing it today and I got 2 different readings by switching the tester leads
power to white and ground to green: i got between 1.0 and 1.4 ohms but stayed at 1.2
And
Power to green and ground to white it went between 1.0 and 1.2 ohms but stayed at 1.0
Should I replace the stator according to these numbers or do you think I have another issue?
I snapped 2 pics as well
1 - 5 of 5 Posts
