with or without the body garnish the Grom looks good.Decent piece to ad on asd a garnish to make it look like a vent but I like it better with out this piece. What do you guys think?
that I wish I knew but looking at it, it there's no where you can screw it in so my best guess is that it might clip in with those ridges or even stick on with double sided 3M tape, or even a combo of both so you can lessen your chance of losing it.I guess your right about that.
So how do these mount on to the Honda Grom?
thanks, had a feeling it would come down to using silicone, double sided 3M will just deteriorate after a while and depending how fast you go it will come off quicker than most think.You need to stick it on with 3M double sided. However, it is not keen to stay. The best way is a few blobs of silicone sealant for piece of mind. We do carbon versions in case anyone is interested. Honda MSX125 2013- - Tyga Performance
The easiest and most versatile way is to use plastic dip. You just spray it on and if you make any mistake you can just peel it off and start over.what would be the best way to paint the grille black without the black peeling or chipping off? the silver is starting to seem a bit too much for me, stands out more than i'd like it to. hoping to achieve this sort of effect:
very coolYou need to stick it on with 3M double sided. However, it is not keen to stay. The best way is a few blobs of silicone sealant for piece of mind. We do carbon versions in case anyone is interested. Honda MSX125 2013- - Tyga Performance
it sure does by far, thanks for posting pictures of it, found a picture of it on an MSX125 on Tyga's website so everyone can see how it looks on the bike:![]()
The carbon finish garnish piece would look much better than the abs black plastic.
How many of you guys are actually considering the taller windscreen cover for the Grom?check these out...
found it in the Custom catalog from Japan thread. would be wicked to have one of those colors behind this body garnish. a red backing with a carbon fiber body garnish over it on a pearl red Grom would look really good in my opinion.
