Great to know on the 13t, I was going to go 14t but it looks like 13t is the trick.Ive tried the 14 and 13 tooth sprockets on the front...can be had on amazon for <10 bucks a piece.
Acceleration improves a lot, top end slightly.
Im able to cruise at 62-64 mph with a 13t and a KN
Stock I would be lucky to cruise at 55
I guess it depends on the riders weight also, I weight 205 lbs, what is your weight so I can gauge the weight diff vers should or shouldn't change the counter gear to 13t.
I ordered a 14t on Weds so hopefully get it early next week and be able to give some insight.
Back to back video comparison on the same section of road!I have a bunch of 13s and 14s here, I havent had a chance to put them on yet. I will try to do both this weekend sometime and post some info about top speeds, redlines, etc.
First, you should also search for MSX and MSX125 whenever trying to find Grom parts.link to these sprockets? im searching amazon for Grom not seeing anything?
But can't you change the rear out as well....?Theoretical top end is like 75 stock geared, obviously the bikes just dont have the power to get there.
Going down 1 or 2 teeth allow the motor to get going quicker, trying to push the top end of 4th faster, but still not redlining out. Some are redlining with 13T I think.
I'm just being a pain. I know that decreasing the front with increase the pickup... But can you decrease the front sprocket and increase the rear sprocket? I remember watching a video where the explained it in depth on how some changes would be equivalent and why you wanted xx front sprocketYou can, yes. Has anyone investigated that yet? I will tomorrow I guess!
