i'd say every 2000 miles or so.. maybe a little more depending on the quality. which filters were you thinking of using?What is the life-span on the OEM engine air filter? Are there currently any aftermarket Grom/125 engine air filters that would be "better" than the OEM filter?
^ that is from a total motorcycling review of the Thailand Market MSX125.filter provide reliable and quiet airflow; the filter itself has a life of 16,000km
It was just a rough guess referring back to the ruckus mileage. But there are quite a few variables to consider on individual bikes.About the region i ride in, it will mainly be suburban area's, busy city, and if i run into them which are a few, construction sites which will definitely kill the life of my filter.
I don't think it would be fair to base the Grom air filter life off of the Ruckus, they seem totally different to me, 2000 miles also seems too little, i was guessing at least 5000 miles
I guess they are just riding till the filter is completely covered up and up to its life span.^ that is from a total motorcycling review of the Thailand Market MSX125.
For Americans that go by miles, 160000KM's works out to be just under 10000 miles.
that's right, 16000 km's just doesn't mean you can ride for 16k and not touch the filter once but giving it a cleaning and even a bit of filter oil to do a better job at catching the debris will go a long way.I guess they are just riding till the filter is completely covered up and up to its life span.
But to keep the bike flowing properly a reusable filter would be best since you could just rinse re oil and reuse.
You don't want your filter to look like this
i remember my mechanic showing me my filter after 1300 miles.. it looked like this, i was horrified!that's right, 16000 km's just doesn't mean you can ride for 16k and not touch the filter once but giving it a cleaning and even a bit of filter oil to do a better job at catching the debris will go a long way.
when your filter is this dirty you'd be surprise how the bike would feel after words. All the power will come back. That is one filthy filter though. I think once a few members start to get there Groms they should show every one on here how easy it is to remove and check the filter.I guess they are just riding till the filter is completely covered up and up to its life span.
i'd go with the oem filters.. i've found the performance on some of the reusable ones i've used to be sub-par.In this case I will be checking my filter VERY often I would hate for this to happen to mine. It would rob from the performance like one had mentioned on here.
Would you guys get a reuseable filter for your Grom or just stay with the OEM filter?
