So I decided to build my own extension for the stock swing arm. Im usually the type to use what is already existing and modify it to suit my needs. I designed this kit to be a 5" extension which could also be modified to be shorter in length if one chose that route. The 1"x2" extension tube is stock wall thickness with an inner sleeve that is rosette welded in place. On the outside has a fish plate to strengthen it up even more for the added leverage. I designed a new lower shock mount but once I was able to test out the drop amounts, I realized it drops the bike a little too much, so that is going to be re-designed. I do plan on selling these as a DIY kit so I designed the entire kit to pretty much be user friendly even down to the template plate used to scribe and cut off the rear of the swingarm to mate up to the extended piece. Here is what I have so far. Let me hear some inputs, good or bad, be easy though....... haha
