Installed Burns Moto USB port. Can be used for iPhone, iPod, GPS, etc....
You can see wire routing and used battery mount bracket to hold wiring in place. I just ran it up under the side panels on same route as main wiring harness....so, it just follows same routing
View of plug mounted and waterproof cap closed
Unit with USB plug inserted
Rider view of plug with wire attached (I used pink cable to make easy to see)
It is ALWAYS LIVE, so it will charge phone or other USB port device with the key in the OFF POSITION....but does not drain battery unless something is plugged in, so as long as you don't have something plugged in, you're all good
My phone plugged in (screenshot) and you can see it is charging (see battery in upper right corner)
