Figured Id take some pics of the process - I installed a Shorai battery in my Grom today.
There are 3 options available for the Grom as far as Shorais go.
The stock battery: Yuasa YTZ5S
65 CCA (Cold Cranking Amps) 3.5 Amp Hours
Shorai stock replacement: LFX07 - $100 retail
102 CCA 7 aH
Shorai upgraded replacement (what I used): LFX09 - $115 retail
135 CCA 9 aH
If you are looking for a BEAST battery for lots of aftermarket accessories or want to run your Grom all night with the running lights on lol: LFX14 - $160 retail
210CCA 14aH
The Shorai case is almost identical in size to the OEM battery, no spacers are needed. The bracket is a tight squeeze to get back on but you can see it does fit. Enjoy saving a couple pounds in weight and knowing your bike doesnt need to be on a battery tender anymore, along with it now having more reserve power than stock!
And a little sneak peak of the next mod to the SikMoto Grom
102 CCA 7 aH
135 CCA 9 aH
210CCA 14aH
