G
Guest
·If you install LED turn signals you WILL need either to use resistors or an LED turn signal relay. Personally I would never use resistors so I chose a LED relay. The relay is located under the fairing to the right of the rear seat. So you have to
If you install LED turn signals you WILL need either to use resistors or an LED turn signal relay. Personally I would never use resistors so I chose a LED relay. The relay is located under the fairing to the right of the rear seat. So you have to take off the entire backside of the bike, which include the drivers seat and the panels under the drivers seat. Sadly I did not take any pics along the way, but I did want to post up I bought a Universal LED relay from Cycle Gear and it worked great! The one that claimed it would fit any Honda did not fit so do not buy one of those! I had to do this because I installed LED rear turn signals..
I have a set of front LED turn signals in the mail so I will know once we get them if we will have to do any sort of Diode mod like what was required on the 250R.
