1 remove 2 bolts that hold on caliper and 1 nut that secures brakeline to fender, remove caliper
2 remove 4 allen heads and 2 nuts from fender and remove fender
3 remove front wheel by loosening and sliding axle out. Dont lose the spacers one on each side of hub. They are identical
4 loosen both triple clamps and slide forks out
5 i wrapped a towel around both forks and put them in my vise then turned the large nut counterclockwise
6 once the nut is loose start pumping the fluid out until you get no more drops(takes awhile)
7 get youself whatever weight fluid u want and add 200 cc to each fork(i used 30 wt bel ray fork oil). Best way to do it is add the 200cc in thirds. What i mean is add a third of the 200cc then put cap back on snug and pump the fork . Do this until you have your 200ccs
8 tighten the top cap back on fork and reassemble!
