1 - 9 of 9 Posts
cost 1.52$$ looks way better with the wailtail gone. there was 2 bolt holes from where the fender came off under the bike. i went and got 2 l brackets from the hardware and mouted them in the existing holes. those holes are the same spacing as your plate holes so then i just screwed on the plate.simple. its far enough back the tailight shines on it and i dont care about turn signals
awesome. someone should post a DIY on how to make a DIY fender eliminator.
I used the stock tag bracket drilled 2 new holes and bent it where I wanted it. A metal brake and drill press made it easier but you could just slot the holes with a die grinder. Im even going to use the reflector mounts on the side for signals if there is enough metal there
1 - 9 of 9 Posts
