1 - 15 of 15 Posts
i run rotela t6 in everything i own.
Reactions: gpd211 and Lanceoa
I think some guys are using the Honda stuff, I will trade to synthetic Castrol or Valvoline at 700 or so.
I'd be careful of the car oil. The type that is marked "Energy Conserving" has additives in it that will make clutches slip. The synthetic that is geared towards the motorcyles is becoming more readily available. Just stay away from the energy conserving oil and you'll be OK.
If you use that valve make sure you leash that thing closed. Way to easy to empty the engine in the middle of a ride and fall on you head.
Great suggestion...
By the way, that valve won't work for the Grom. It's it pretty bulky and wont' clear those metal tabs surrounding the drain plug.
You might get away with using a long adapter, but I don't think it would look very attractive.
1 - 15 of 15 Posts
