Tail Tidy/Fender Eliminator for GROM/MSX125
Introducing the ComposiMo Tail-Tidy for the Honda GROM!
When i first got the Grom/MSX125, the tail end of the thing was SO UGLY with that HUGE "ski-jump" rear fender... haha! So one of the very first things i put my mind to was making a slick Tail Tidy that would fit the bike well, but more importantly be able to use the OEM lights. I know a loto f guys like to go to small indicators and such, but a LOT of people really like the stock indicators so that people on the road will hopefully see them better.
The big issue with the blinkers is the actual clearance between the right blinker and the muffler. There isn't a lot of room there. But there IS enough
Blinker Clearance:
The ComposiMo Tail Tidy is made from 1/8" thick STAINLESS STEEL, and comes powder coated in a flat-black finish so that it blends into the bike much better. I've seen far too many stories of cheap, thin aluminum tidy's breaking over time due to vibration, and when made of regular steel, they get chips and stuff in them from rocks on the road, and so they just RUST! With the Stainless Steel 'Tidy, rust won't be an issue at all, and the durable powder coat will help ensure it stays nice looking for a long time!
There are two versions available...
One is made to mount your license plate, and even use the stock license plate light! Stay legal AND look good doing it!
The second version mounts the blinkers, and has a very nice 'cover plate' bent to cover us the blinker mounts and the wiring, so that you don't have to look at that stuff. This 'Tidy should be used if you are planning on mounting your license plate somewhere else on the bike.
This is the nicest, and most robust Tail Tidy you'll find! No expense spared in the manufacturing of the 'Tidy! Sure, i could have made it out of aluminum or regular steel, but whats the point if its only going to break or rust on you?
Stainless Steel Hardware INCLUDED!
Without License Plate Mount:
With License Plate Mount:
- Precision Laser-cut, and CNC Bent for accuracy!
- Stainless Steel!
- Powder Coated Black!
- Bolts up like Factory!
- Stainless Steel Hardware Included!
